Recommendation for Replacement belt for Performax 10-20
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50998
Author:  Glenn LaSalle [ Thu Sep 20, 2018 11:32 am ]
Post subject:  Recommendation for Replacement belt for Performax 10-20
Hi Folks,
My belt gave out on my Performax 10-20. I had gotten a replacement that fit well, but was very flimsy... said it was 120 git... When I put some backs through the sander, the wood got stuck under the drum.. the belt was spinning but didn't move the wood through. Note: I am not talking about the sandpaper... rather the belt
Has anybody replaced the belt successfully with something they are happy with?
I see this a woodcraft:
https://www.woodcraft.com/products/repl ... 6QQAvD_BwE
This one as well:
https://www.mmtoolparts.com/store/jet-p ... -60-0310-p
And here:
https://www.highlandwoodworking.com/dru ... -belt.aspx
Any help is appreciated!
Thanks!
Glenn
Author:  CarlD [ Thu Sep 20, 2018 1:59 pm ]
Post subject:  Re: Recommendation for Replacement belt for Performax 10-20
I used one from these guys for my 16-32.... https://2sand.com/feed-belt-for-jet-per ... rum-sander. Works fine but the one from Highland is a great price and appears to be very similar.
Author:  Joe Beaver [ Sat Sep 22, 2018 4:43 pm ]
Several years ago I replaced my 16/32 feed belt with one from the internet. It was several months before I actually installed it. It was made from quality material but somehow they made one side slightly shorter than the other. When i tried to contact them it seems they had a 30 day return policy so I bought the next one from woodcraft. It works fine.
The missed fitted one still worked but I couldn't tighten the loose side without changing the tracked so severely it ran off the guides. I grumbled some but did manage to use it for a few years (running loose on one side).
The moral of my story is get one from a dealer where you can easily return it if needed.
Author:  George L [ Sat Sep 22, 2018 6:52 pm ]
I had to replace mine a couple of years ago. I bought this one from Woodworkers Supply on Amazon and it has worked fine:
https://www.amazon.com/Abrasives-156155 ... dpSrc=srch
